dosing fert
alexandre
Jun 26, 2005
I am dosing every 2 days
Flourish nitrogen = 20ml
K2S04= 5 Grs (dry)
KH2P04= 0.2 Grs (dry)
And Flourish 3ml 2 x a week.
My aquarium is 40G
2.5 WPG
Pressurise CO2
N03 = 5/10 ppm
PO4 = 0.5 ppm
PH = 7
KH = 12
Water change 30% weekly.
Are those dosage all right my nitrate seam very low (might be my test kit) with the quantity of Flourish nitrogen I add. Should I change some thing?
Thanks.
alexandre is online now Edit/Delete Message
alexandre
Jun 26, 2005
Re: dosing fert
Jut want to check if my dosages are all right as I just started to use dry ferts and I am a bit confuse about how to dose Flourish nitrogen, it seam to me I add a lot of it.
turbomkt
108
San Diego, Ca
Re: dosing fert
If you're dosing dry ferts, why aren't you dosing KNO3?
Anyway...according to Seachem you're dosing right. $.02
alexandre
Jun 26, 2005
Re: dosing fert
Because I am currently living in Cyprus and KN03 can not be send via airmail. I will have to try to find some over here.
turbomkt
108
San Diego, Ca
Re: dosing fert
That makes sense.
As far as the Flourish N goes, you could ask in the seachem section at APC to see if you can go higher or if all of the N is from NO3. It's possible there are other N sources in Flourish that won't register on a nitrate kit.
Laith
182
Geneva, Switzerland
Re: dosing fert
From Seachem's website:
"Because one-half of the nitrogen in Flourish Nitrogen™ is from nitrate you can get a reasonable estimate of nitrogen levels by doubling a nitrate reading"
This of course assumes that your nitrate test kit is giving correct readings...
alexandre
Jun 26, 2005
Re: dosing fert
Thank you for the answers.
SO it look like I am dosing all right Flourish nitrogene. What is the seachem section at APC?
