I am just about ready to order ADA AS and PS special and needed some more advice on dosing for my 80G tank.
I have already been doing the EI method for a year and a half now. Tom if you remember you had advised me to use peat/laterite beneath my gravel, and initial start up was to keep the lights low, with full dosing of ferts and CO2, then after two weeks light go full blow.
In my previous thread you mentioned that the dosing would be the same with the nutrient rich AS, so business as usual with EI.
This time my tank will be completely torn down and I will start from scratch, but I will still save some of the mulm and a few plants from my current tank to speed up the cycle, and use Stability. (I can even save a handful of the old gravel) which can be placed below the PS.
So question is, how will the initial start up be? I have been told in another forum that I should not dose anything expect K for 4 to 6 weeks and for that I should use Brighty K.
I have a lot of dry ferts in stock, KNO3, PO4, Mg, SO4, CSM and also TMG. These are far cheaper then the ADA liquid ferts, which do the same thing.
1/ What do I dose in the first 2 weeks while the lights are low? Just one dosing or the usual 3 times a week? With low lights plants won't need so much ferts?
2/ CO2 as usual should be at full speed.
3/ Should I keep lights at 144 watts in the initial two weeks?
Could you give me a start up regime for at least 2 weeks to a month? If you think that initially I might need Brighty K and Green Bectar then I can order it with the AS/PS.
I’d appreciate your advice.
