C
csmith
To follow is a rough sketch of my plans for my 55 gallon. Everything is fairly close to scale. I'm looking for opinions on if this plan will work out basically. Also, input on my methods of flow dispersement (as in the hardware) is appreciated. For the powerheads I'm considering placing each a few inches lower than the previous one to ensure full, circular flow from top to bottom. I've also yet to decide where to place Co2 flow and how to diffuse it. I also only own 1 Koralia Nano, so the other two can be substituted with something else.
Legend:
Black - Perimeter of tank.
Red - 2 inches from glass at substrate level I won't be using. I like the perimeter with a clean look. Could probably cut it back to 1 inch.
Dark Green - Total flora thickness at substrate level. 6" in middle, 12"x18" outsides. Very rough estimate.
Light Green - Carpeting plant.
Blue - Powerheads with final depth of each TBD (3 Koralia Nanos claimed at 240 gph each, connected by a Ocean Pulse Wavemaker) / Filter spray bar(15 inches long with a claimed 260 gph coming from a Fluval 305) running just under the surface for surface agitation with slight angle down.
Gray - Optional spray bar extension (15", not sure if it's worth using)
Purple - Filter Intake.
Orange - Heater.
Yellow - Flow pattern.
Thanks for any and all input.
Legend:
Orange - Heater.
