Does bromothymol blue affect the reference solution's dKH?
Discussion in 'CO2 Enrichment' started by Richard McConchie, Jun 6, 2016.
  1. Richard McConchie
    Richard McConchie Junior Poster
    Jun 6, 2016
    11:40 AM
    Hi. I'm fairly new to CO2 injection and have been calibrating my 420 litre tank for the last couple of weeks. I have two drop checkers of different design. The first (one of those nicely curved glass units) is mostly blue to blue-green and changes colour only slowly. The second (which is located right next to the first) is a glass sphere with a hollow cylinder stuck into it. It changes relatively rapidly to a bright green to lime green.
    Both are loaded with my home made 4 dKH bicarb solution (17 drops in 20 ml from an API test kit). The only way I can think to resolve the discrepancy is that there may be more bromothymol in the second unit (the design makes the colour less easy to see). I was thinking that if the bromothymol is made up into solution with distilled water it could lower the dKH of the combined (reference + bromo) test solution, and the more bromo you add, the yellower the result at any particular CO2 level.
    Does this sound plausible?
    #1 Richard McConchie, Jun 6, 2016
  2. Dennis Singh
    Dennis Singh SynKing!
    May 5, 2013
    2,417
    639
    3:40 AM
    Sorry RM, i don't think anyone knows or they would've chimed in by now.
  3. Richard McConchie
    Jun 6, 2016
    11:40 AM
  4. Justlikeapill
    Justlikeapill New Member
    Jul 26, 2015
    24
    11:40 AM
    If you are using the same solution and they are side by side then it is because of the different designs. If I understand your descriptions, the faster one just has less airspace so it reaches a reading faster.
    I would think the type that hangs on the "rim" of an aquarium (a tube that's bent into a U-shape) would be extra slow.
