Do these parameters sound alright?
ccLansman
Jan 22, 2008
375
Vista, Ca
Just used a test strip and here are my readings. How do i switch ppm kh and gh to the degree number.
Specs:::
No3 = 40ppm
GH = 300ppm
KH = 200ppm
ph = 6.8
High, low?
GH and KH are not at all critical, so I just divide ppm by 20 to get a rough estimate of degrees of hardness. I can easily do that in my head. You have hard water.
I doubt that your KH is that high, which makes me doubt that your GH is that high either. If your KH was that high I would expect your pH to be higher. I suspect the problem is using test strips to measure those values. Test strips are very crude estimates, not measurements. It is hard enough to trust a test kit measurement of KH, pH and GH, without calibrating the kits, but using test strips is basically just guessing.
ccLansman
Jan 22, 2008
375
Vista, Ca
lol great, thanks for bursting my bubble VaughnH, i guess im out, i paid 20 bucks for a box of these damn test kits :)... o well they should be ok for nitrate and ph ..
