Do i need to add more plants?
ganjero
Oct 25, 2007
7
This is my 20g long. I'm gonna remove the power head soon. I was thinking in adding some background plants but I don't know what. Maybe blyxa? or should I leave it the way it is? What do you guys think?
Open to all suggestions
08/05/2007
10/14/2007
How about some of the taller Crypto species? Many have olive/brown/reddish leaves that I think would contrast well. C. Wendti or Undulatus might look good there. Sorry, I love Crypts...
Or, Rotala macran, or some of the Ludwigia species would like nice.
Or, how about vallisneria or sagittaria for the back if you want to keep shades of green......
I have no exp with some of the more 'delicate' red/brown stem plants, so I cannot advise too much there.....
Nice tank BTW......
You may want to trim the foreground a little to make them shorter. The nice mountain will stand out a little more.....
Good luck!
This is what I'd suggest:
Mow the lawn!
Trim the hair grass to about 3-4 cm.
Even all the way across.
Do not worry, it's a grass just like the grass outside in a lawn and it will grow back.
Use some decent size scissors, hair cutting scissors tend to work well.
You can trim the moss to your choosing and shape.
You can also add some manzanita branches or similar twigs/branches coming out from the behind the moss mound.
Behind this, perhaps a nice fine needle red plant etc, say L arucata etc.
Up to you really.
You can also pull the front edge back so you slope the gravel front to back, you can also trim the lawn to keep it short in the frotn and taller in the rear to yield a similar effect.
What you do here is up to you as far as scaping, but simple tanks are very nice and show more discpline.
Mow the lawn!
Up to you really.
You can also pull the front edge back so you slope the gravel front to back, you can also trim the lawn to keep it short in the front and taller in the rear to yield a similar effect.
What you do here is up to you as far as scaping, but simple tanks are very nice and show more discipline.
