I've been trying to work out why my Red Ludwigia isn't red. At first I took the knee jerk responce and uped the Fe. It's at .75 ppm/day auto dosed on a constant drip as are KNO3 and KH2PO4.
Other ppm/day dosing rates are:
NO3 - 4.25
PO4 - 2 (Up from .75 to work on some GSA)
K - 4.32 (2.68 from the KNO3 and 1.64 from the KH2PO4)
Weekly water changes 50% for future reference may tap has little to no NO3
I read somewhere that high nitrates would reduce the red in plants so I made some ref. solutions and calibrated my API NO3 test kit. Standard two bottle test. The instructions call for 10 drops of each (agitating and timing as instructed ,of course) and I found that the correct drop count for "my" kit and the ref. sols. was 8/8. When I tested the tank I got a high reading >100. OK, check for all sources for decomposing bio matter, reduce feeding, water change, clean filters. Wait a couple of days; recheck ... still over 100. I know not really bad for fish, but why? OK then, ... I'll cheat ... 1 100ml bag of Purigen in each canister on a 80g water column. Wait 4 days ... still over 100.
Back in February when I set up the tank I laid down 60g of Osmocote.
(6 sq ft ... 10g/sg ft.)
Could that be the issue with the NO3? Cause if is I'm just chasing my tail till it burns off. Or should I still look for something else?
Pat
NO3 - 4.25
Pat
