DIY Trace Mix
tirtha1979
Jul 10, 2007
45
43
Hyderabad, India
Hi Tom, In India, no branded Trace Mix is available for planted tanks. So we used to use an Agriculture grade Trace Mix (Microsol-B/Fetrilion-Combi) along with an Iron Suppliment (Fetrilon(13% chelated Iron)). But now a days, that company went crap and screwed up the quality. So I was wondering if we can make our own trace mix.
Which all the chemicals I need to use to make the Mix?
How much we have to mix together and how much to dose?
I am looking for a Trace Mix as well as a separate Iron Mix.
Here is the Trace Mix composition in Fetrilion-Combi
Iron 4%
Zinc 4%
Manganese 3%
Copper 0.5%
Boron 1.5%
Molybdenum 0.05%
Magnesium 2%
Sulphur 2.8%
Please suggest.
Tropica Master Grow contained: K 0.79%, Mg 0.39%, S 1.01%, B 0.004%, Cu 0.006%, Fe 0.07%, Mn 0.04%, Mo 0.002% Zn 0.002%. HEEDTA and DTPA as chelators. This is from: Tropica Fertilizer. I didn't keep looking, but I recall that "the Krib" also has the constituents of Plantex CSM in one of the posts there.
This is fine,m if you can find some Iron chelate alone, add about 1:1 ratio with this product, then add about 5grams of this to 500ml of DI water.
You might need to add a little HCL acid, say 1 ml of 9 Molar HCL.
