DIY PVC Mame overflow instructions
Discussion in 'Articles' started by Tom Barr, Mar 13, 2013.
  1. Tom Barr
    18,693
    726
    12:05 PM
  2. Tug
    Tug Lifetime Charter Member
    Jan 5, 2009
    1,150
    12:05 PM
    Here is a very similar design.
    [video=youtube;wHrpG8jG0Uk]http://www.youtube.com/watch?v=wHrpG8jG0Uk&feature=share&list=PL5aY5kj8XLqjNoOA4ld50TDaul4xZUlXz[/video]
    http://www.youtube.com/watch?v=wHrpG8jG0Uk&list=PL5aY5kj8XLqjNoOA4ld50TDaul4xZUlXz
    The placement for the check valve is a little further forward on this design but I don't know if that maters. I also like, the return strainer ruddybop uses instead wire ties. Running a line from the overflow to a return pump with a venturi fitting was my thought too.
    #2 Tug, Mar 13, 2013
  3. SkinnyWhitekid
    SkinnyWhitekid Junior Poster
    Mar 13, 2013
    12:05 PM
    He takes a saw blade to that pvc cap though.. Ive literally tried it like 100 times and can never get the drain to look like that haha
  4. Tom Barr
    18,693
    726
    12:05 PM
    The wire mesh they use for moss etc, stain steel etc, you can simply cut that and bend it to make the over flow screen, I do that to keep shrimp out of filters on some tanks etc.
  5. Tug
    Jan 5, 2009
    1,150
    12:05 PM
    Here is how ruddybop cuts the caps. I think a handsaw would also work but the method he uses to hold the cap in place keeps it steady during the cutting. I would add some over flow screen or a pre-filter to the design.
    Making PVC overflow strainer out of pvc cap.
    http://www.youtube.com/watch?v=Ajy7mDPGR2M&feature=share&list=PL5aY5kj8XLqjNoOA4ld50TDaul4xZUlXz
    Here is a DIY Stockman Style Overflow Silencer by the same guy.
    http://www.youtube.com/watch?v=M2um4kzWgYw&feature=share&list=UUPaEKgyL3JGpCNXeVtMiOLg
  6. -DAVE-
    -DAVE- Junior Poster
    Oct 27, 2012
    12:05 PM
    Your setup?
    Tom,
    I have read where you use sumps on many of your large tanks....I am in the process of setting up a 55gl low tech non co2 planted angelfish tank with a 30 gal sump....
    Should I use one of these for the overflow to the sump with the input in the sump below its water line to preserve my co2???
  7. Tom Barr
    18,693
    726
    12:05 PM
    In the non CO2 tank, you want to have degassing at a high rate. This keeps the CO2 at a more constant ppm, but it's low, 1-2 ppm typically.
