DIY project using algae as export in SW
SantaMonica
Sep 19, 2008
155
Santa Monica, CA, USA
Part 1 of 2:
For those interested in natural exports in SW, this DIY may be of interest:
An algae filter screen, also known as a turf algae filter, a turf scrubber, or an algae scrubber, basically filters the water clean of nitrate and phosphate so that the green on your rocks and glass goes away. It does this by "moving" the growth of the algae from the tank to a "screen" outside of the tank. The idea is that you create a better growing environment on the screen than occurs in the tank, so that the algae grows on the screen instead. It works great!
Here's what you can expect: If you build your algae filter properly, your nitrate and phosphate will be incredibly low, sometimes unmeasureable by hobby test kits, within four weeks. I use Salifert test kits, and the readings I get are "clear" (zero) for both the Nitrate and the Phosphate tests. This is what you want. If you have been trying to get this yourself, then an algae filter is for you.
Here is my Algae Filter in a 5-gallon bucket; it's the only filter I have (other than the live rock) on my 100 gallon reef:
http://www.radio-media.com/fish/BucketOnSink.jpg
Here is the filter in operation with the lights on:
http://www.radio-media.com/fish/BucketInOperation.jpg
Here is my tank:
Hi-Res: http://www.radio-media.com/fish/WholeTank.jpg
Video: http://www.radio-media.com/fish/WholeTank08-11-08.mpg
And here are the only things you need to build a bucket version of this filter:
http://www.radio-media.com/fish/AllPartsSmall.jpg
My nitrate and phosphate are zero (clear on Salifert test kits), and the only thing in my sump is water. I removed the skimmer, carbon, phosban, polyfilter(s), and filtersock; I don't use ozone, vodka, zeo or anything else. I'm feeding massive amounts too; enough that if I had my previous filtering setup, I'd have to clean the glass twice a day, and everything in the tank would be covered in green or brown algae.
The only thing you need to decide on is how big your algae filter screen needs to be, and if you want it to be in your tank's hood, or in a bucket, or in your sump. The basic rule is one square inch of screen for each gallon of tank water, if the screen it lit on both sides; the screen size should be twice this if the screen is lit up on just one side. A 12 X 12 inch screen, lit both sides, = 144 square inches = 144 gal tank; a 7 X 7 inch screen lit both sides = 49 gal tank; a 6 X 6 lit both sides = 36 gal tank. Algae filters get really small as you can see. A 12 gal nano tank needs just 3 X 4 inches! This small thing can replace the skimmer, refugium, phosphate removers, nitrate removers, carbon, filtersocks, and waterchanges, IF THE PURPOSE of these devices is to reduce nitrate and phosphate. If these devices have any other purpose, then they can't be replaced. If your tank is bigger than a 75, then just start with a 5 gallon bucket size and see how it goes. You can always add a second one, or build a bigger one later.
My example bucket version takes about 4 hours to build. Water goes in the pvc pipe at the top, flows down over the screen, then drains out the bottom. That's it! Oh, and it has clip-on lights. I can feed the tank a lot of food, and anything not eaten by the corals or fish eventually ends up as algae on the screen.
Here are some examples of DIY algae filter screens already built, from a simple nano one:
http://www.radio-media.com/fish/5galNanoCompartment.jpg
http://www.radio-media.com/fish/5galNanoLight.jpg
to larger ones:
http://www.radio-media.com/fish/UserMinzukOnUR.jpg
http://www.radio-media.com/fish/UserI_limantaraOnAC.jpg
http://www.radio-media.com/fish/UserJohntOnUR-7.jpg
http://www.radio-media.com/fish/UserThauro77onSWF-5.jpg
SantaMonica
Sep 19, 2008
155
Part 2 of 2:
How to build it:
First, get your screen. Any stiff material that has holes in it, like knitting backing, plastic canvas, rug canvas, gutter guard, or tank-divider will do. Try going to hardware stores, craft stores, garden stores, sewing stores, or just get one of these online (in order of preference):
http://www.craftsetc.com/store/item.aspx?ItemId=43844
3.75- & 5-mesh Rug Canvas Assortment, 5 Pieces
Aquatic Eco-Systems: Tank Dividers
Don't use window screen though. The main problem with this kind of "soft" screen will be getting it to hold its shape; it will bend and fold too much. Stiff screen is easier to make stay put, and easier to clean.
If you have a nano with a filter hatch on top of the hood, then it's super easy: Just cut a piece of screen to replace the sponge filter, and put it where the sponge filter went. Leave the hatch open, an set a strong light on it, facing down directly on the screen. This is a good bulb to get; it will be bright enough to power the screen, and to light up your nano too:
23 Watt R40 Compact Fluorescent Flood 5100K Full Spectrum CFL
If your nano does not have a filter hatch on top of the hood, or if you have a regular tank, then here are the larger versions:
The first and main thing to consider is the flow to the screen. You need about 35 gph (gallons per hour) for every inch of width of the screen. Thus, a 2" wide screen would need 70 gph, and so on. Here is a chart:
Screen Width-----Gallons Per Hour (GPH)
1" 35
2" 70
3" 105
4" 140
5" 175
6" 210
7" 245
8" 280
9" 315
10" 350
11" 385
12" 420
13" 455
14" 490
15" 525
16" 560
17" 595
18" 630
19" 665
20" 700
Note that it does not matter how tall your screen is, just how wide it is. Let's start with an overflow feed: In this case the amount of flow is pre-determined by how much is overflowing; the maximum flow you'll get to the screen will be what's going through your overflow now. This is easy to figure out by counting how many seconds it takes your overflow to fill a one-gallon jug:
60 seconds = 60 gph
30 seconds = 120 gph
15 seconds = 240 gph
10 seconds = 360 gph
8 seconds = 450 gph
5 seconds = 720 gph
Take this gph number that you end up with, and divide by 35, to get the number of inches wide the screen should be. For example, if your overflow was 240 gph, then divide this by 35 to get 6.8 (or just say 7) inches. So your screen should be 7 inches wide. How tall should it be? As tall as can fit into the area you have, and, as tall as your light bulbs will cover. But how tall it is not as important as how wide it is.
Pump feeds: Since with a pump you have control over the flow, start with the size screen you can fit into your space. If the screen will go into your sump, then measure how wide that screen will be. If the screen will go into a bucket, then measure how wide that screen will be. Take the width you get, and multiply by 35 to get the gph you need. For example if you can fit a 10 inch wide screen into your sump or bucket, then multiply 10 by 35 to get 350 gph. Thus your pumps needs to deliver 350 gph to the screen.
You can construct your setup using any method you like. The only difficult part is the "waterfall pipe", which must have a slot cut lengthwise into it where the screen goes into it. Don't cut the slot too wide; just start with 1/8", and you can increase it later if you need to, based on the flow you get. I used a Dremel moto-tool with a "cut off wheel":
Now install the pipe onto the screen/bucket by tilting the pipe and starting at one side, then lowering the pipe over the rest. You may have to wiggle the screen in some places to get it to fit in:
http://www.radio-media.com/fish/PipeInstall.jpg
Lighting: This is the most important aspect of the whole thing. You must, must, have strong lighting. I'll list again the bulb I listed above:
... This the minimum you should have on BOTH sides of your screen. You can get even higher power CFL bulbs, or use multiple bulbs per side, for screens larger than 12 X 12 inches, or for tanks with higher waste loads. The higher the power of the lighting on the screen, the more nitrate and phosphate will be pulled out of the tank, and faster too.
Operation:
Regardless of which version you build, the startup process is the same. First, clean the screen with running tap water (no soap) while scrubbing it with something abrasive. Then dry it off and sand it with sandpaper on both sides. Then get some algae (any type) from your system and rub it HARD into the screen on both sides, as deep and as hard as you can. Then run tap water over the screen to remove the loose algae pieces; you won't see the spores that stick... they are too small, but they are there. Don't forget this algae rubbing part... it will speed up the start of your screen by a few days. Install the screen and turn on the water.
You can leave the light on for 24 hours for the first week if you want to speed up the process; otherwise just put it on a timer for 18 hours ON, and 6 hours OFF. You will see absolutely nothing grow for the first two days. On day 3 you'll start seeing some growth, and by day 5 most of the screen should have a light brown coating. If this level of growth does not happen on your screen, your lighting is probably not strong enough, or it's not close enough to the screen. Increase the bulb power, or move it closer.
When the screen looks something like this:
http://www.radio-media.com/fish/ScreenBuildDay9outSmall.jpg
...then you want to give it it's first cleaning, on ONE SIDE only. Take the screen to the sink, run tap water on it, and just push the algae off with your fingers (not fingernails):
http://www.radio-media.com/fish/ScreenBuildDay9scrubbing.jpg
Wait a week, and clean the other side, gently. Wait another week and clean the first side again, etc. After a while you'll have to press harder to get the tougher algae off, and after a few months you'll probably need to scrape it with something, and it may eventually get so strong that you'll need a razor blade to scrape it off. But for now, be gentle; you always want some algae to remain on the screen when you are done. NEVER clean it off completely.
Don't forget to test your Nitrate and Phosphate before you start your filter, and each day after. Post your pics of how you build it, the growth day by day, and your nitrate and phosphate readings, so we can all see how you are doing.
Carissa
Jun 8, 2007
678
Great! I'm just getting into SW and was wondering what I would do if I needed additional nutrient export....I didn't really want to get into keeping macroalgae etc. I might give this a try!
SantaMonica
Sep 19, 2008
155
Reminder Of The Day:
What Scrubbers Consume: Algae scrubbers consume INORGANIC nitrate and phosphate. These things are what your test kits read, and what the nuisance algae on your rocks and glass require to live. What scrubbers don't consume is ORGANIC nitrate and phosphate. Organic nitrate and phosphate have another name: Food. Any and every piece of food you put into your tank has nitrate and phosphate in them, but they are organic. Scrubbers leave them in the water for the corals to eat. Skimmers do the opposite: Skimmers remove the organic nitrate and phosphate (food), and leave in the inorganic nitrate and phosphate; these inorganics are then used by the nuisance algae on your rocks and glass to grow.
Carissa
Jun 8, 2007
678
So a skimmer/algae scrubber combo would be ideal, from the sounds of it, to do maximum nutrient export. Doesn't food also turn into inorganic nitrates/phosphate though over time?
SantaMonica
Sep 19, 2008
155
For maximum export, yes a combo. For example, for fish only, or fish with live rock. However, being that it's free, you might just start with a scrubber by itself. I'm sure you won't have too much livestock in your tank to begin with.
Carissa
Jun 8, 2007
678
I have a skimmer, but it's a junky one. :)
I wonder if this would work for a fw planted tank? The goal isn't total nutrient export - but I'm curious to know if it would have an effect on algae in the tank or not. I have a 2g nano that I'm going to try it on just for kicks, to see if it reduces nitrates. It's a low maintenance tank with a few java ferns in it, and I can't put high light on it because it will cause algae and turn into a high maintenance tank, but at the same time my nitrates are climbing.
TheRac25
Sep 22, 2008
This could also serve as a water chiller due to the evaporative cooling effect, sub-ambiant temps could be acheived with other heatsources removed from the tank.
This is what the towers you see at nuclear power plants are doing, minus the algae.
PlantedFishGeek
Sep 23, 2008
27
How does this compare in ability to remove nitrate,Nitrite,Phosphate etc to a heavily "planted" fuge with cheato or chulpera?
SantaMonica
Sep 19, 2008
155
Results of the day:
jski711 on the RF site says: "Well i ditched my euro reef skimmer and have not noticed any side effects from doing so. i'm still doing water changes on a regular basis but i have increased feedings tremendously and have no adverse side effects from doing so."
keithqueef on RC says: "Update. Well i received my screen from inland (12x12) last friday. and since putting it into my system my trates have gone from red to orange to now dark yellow not quite orange, i lost my color card so i dunno numbers. the screen is dense with it."
799
I used this method in FW to grow Pithophora for my Labiobarbus(algae eaters).
Must have been 20+ years ago.
Nice layout and diagram!!
Likely better for marine systems but the refuge has other nicer things and adding the DBS to the fuge is nice and a good home for pods and other critters.
Nice thing is adding the sheets for tangs etc is very easy and you do not have to use Chaeto etc.
Nice write up.
799
SantaMonica;29189 said:
Today's build-of-the-day is the very first solar powered screen that I've seen on any thread. Lighting will not be a problem with this one. Uses a simple pressurized pvc frame:
Not in SM , CA, but in MN in the winter...............it needs to be indoors.
SantaMonica
Sep 19, 2008
155
Ok here is a four-part video I made of the last scraping of the screen of my original bucket before I give it to the LFS to replace the tank-divider screen he's been testing. This video is low-light (with a 5 year old 2-meg camera), so you can't see the algae on the screen, but the purpose is to see the technique of screen cleaning/scraping:
Hi-res:
Part 1: http://www.radio-media.com/fish/Scraping1.mpg
Part 2: http://www.radio-media.com/fish/Scraping2.mpg
Part 2: http://www.radio-media.com/fish/Scraping3.mpg
Part 3: http://www.radio-media.com/fish/Scraping4.mpg
YouTube:
YouTube - Algae Scrubber: Cleaning/Scraping, part 1
YouTube - Algae Scrubber: Cleaning/Scraping, part 2
YouTube - Algae Scrubber: Cleaning/Scraping, part 3
YouTube - Algae Scrubber: Cleaning/Scraping, part 4
PlantedFishGeek
Sep 23, 2008
27
Hi-res:
YouTube:
Couple Questions.
Why would you want to kill pods?
And will Herbivore fish eat what your scraping off?
