DIY LED, 5630 SMD strips.
Discussion in 'Lighting' started by rickwrench, Jan 26, 2016.
  1. rickwrench
    rickwrench Junior Poster
    May 18, 2009
    10:54 AM
    I haven't posted in years, but this project turned out well enough to mention.
    Supplies:
    Two 5m rolls of waterproof "warm white" 5630 SMD LED strips. $11.00 each
    Couple feet of CAT 5 cable. Free.
    Bag of junk store DC wallwarts, 500ma to 2 amps. $1.00 each
    Aluminum sheet scrap (.052" 3003 or 5052, can't remember). Free
    First try was a retro fit of a 5 gallon Pemco SS tank.
    54 total LEDs 12v @ 1.5 amp (so, 18w). %630s are supposed to handle .4 -.5 watts each, producing 45 lumens per LED. The specs are all over the board though, depending on what knockoff version you end up getting. Heat kills LEDs, so I chose to drive them at .33 watts per chip.
    How much light? Most 5630s are rated at about 100 lumens per watt. Insert grain of salt here. I don't have a PAR meter.
    Construction was straight forward. Clean aluminum mounting sheet with acetone, peel of sticky back tape, stick LED strips to aluminum. Solder power feed to appropriate pos/neg tabs. I fed power in from both sides of each strip (which I'd read helps).
    Then I epoxied the whole assembly into a vintage metaframe style SS hood.
    Total cost of materials actually used- about $6.00.
    It's been running about a year now.
    Interesting observations of these leds vs a 32w CFL: The LEDs don't burn up water lettuce or other plants growing above the surface like the CFL does.
    Pic of hood assembly tilted up:
    This worked out so well I lighted a small 5 gallon custom copper hex tank the same way. Except I used 84 chips and a 2 amp power supply. I need to trim back the vals about once a week in this one. Otherwise the Marsilea gets leggy.
    Rick
    2 people like this.
