Hey All,
I cant seem to find a trace mix where I am from so I decided to make my own.
My tank is 100 gallons while my water is 8.1PH which falls to 7.1PH after CO2 injection.
I was able to obtain DTPA FE 11%. The rest of my mix is comprised of Manganese Sulfate Monohydrate, Zinc Sulfate Monohydrate, Copper Sulfate Pentahydrate, Boric Acid, Sodium Molybdate Dihydrate.
The following table represents my percentage analysis:
Is my dosing a half teaspoon okay (3g)? Or should I use a little less than a teaspoon? Like 2.7g?
Please advise, did I use sufficient amounts of the elements in the trace mix?
