CO2 - au naturel !
There is nothing contrary to nature about CO2 (carbon) supplementation for plants. All living organisms need carbon as a food source and macrophytes typically exhibit an increase in both photosynthesis and growth in aquatic environments with elevated CO2 levels of 30 ppm and above.
Plants need carbon, but the levels provided in tank water are often limited due to nutrient demands under high light intensities (PAR) and plant uptake, surface agitation (gas exchange) and low levels of dissolved organic carbon (DOC). This most important nutrient carbon, is regularly lacking in a planted aquarium and CO2 supplementation provides vigorous, healthy plant growth. In fact, aquatic environments with ample CO2 and moderate light exhibit growth rates 4 - 5 times greater then those without CO2 enrichment. Under bright light (80 μmol/m2s), CO2 is essential or a planted tank quickly becomes CO2 limited, leading to growth deficiencies and unwanted algae.
Is CO2 enrichment necessary in low light environments?
CO2 provides a needed nutrient, even in low light. When CO2 is plentiful
plants invest less energy towards capturing CO2 and more energy for optimizing light capturing pigments.
Tropica's study on Riccia and the affect of resource availability on growth.
Diagram courtesy of John LeVasseur
Before purchasing a pressurized CO2 setup, consider using a diy yeast powered generator. Wade through all the pertinent information on dual stage regulators at your leisure (before you spend all that hard earned cash). The experience will prepare you for many of the problems inherent to all types of CO2 supplementation. Fear not, CO2 generators provide plenty of CO2. How it is dispersed into solution is the main problem we have in common with pressurized systems.
The high light requirement myth
http://www.barrreport.com/showthread.php/7503-The-high-light-requirement-myth
CO2 and Light Stimulate Growth, - Tropica
http://www.tropica.com/advising/technical-articles/biology-of-aquatic-plants/co2-and-light.aspx
All You Ever Wanted To Know About CO2 But Were Afraid To Ask
http://aquaticconcepts.thekrib.com/Co2/co2_faq.htm
"At low light and low CO2 there is not much energy to play around with for up or down-regulation of the pools of Chlorophyll or enzymes. If we then add a little more CO2 to the system the plant can afford to invest less energy and resources in CO2 uptake and that leaves more energy for optimizing the light - more Chlorophyll can be produced without fatal consequences from the energy budget. Hence, we have not raised the light and the plants can now utilize any available light - more efficiently." - Tropica
This treatise is not yet complete and I will be updating this thread.
If you need more information or have questions, I can probably still help. Contact me here or check out the forums.
Alternatively, if you think you can provide me with accurate information, please don't hesitate to contact me here.
