First of all, I would like to say "wow" with regard to the amount of technical information I have found on this site. Being an engineer myself, I appreciate the technical aspect of any discussion but appreciate the simple language and approach too. I have found both here!
Since I didn't see a forum for newbie stuff, I'll take a chance and post here.
I've been keeping freshwater fish for ~27 years and also kept a reef tank for ~5 of those years. About this time last year, I decided to convert my freshwater community tank over to a planted tank after stumbling upon some pictures of the AGA aquascaping competition
One of my biggest goals for this tank, however, was to keep it relatively simple and fairly low-cost. That beiong said, here are some of the specifics on my setup:
22G glass tank (standard 24"x12" footprint)
4x15w NO fluorescent bulbs (using the 5,000K "natural sunshine" bulbs from Home Depot)
Fluval 304 canister filter (I know, it's overkill for the 22G but I throttle back the output alot)
standard/regular medium gravel bed ~2" in depth
Fish include:
Guppies... lots of 'em
1 - pleco
1 - red-tailed shark
2 - clown loaches
When I started this project one year ago, I began with the following plants:
1 - Echinodorus amazonicus (mother has gotten freakin' huge and has turned into five plants)
1 - Cryptocoryne wendtii - red (has spread a lot, ~8 plants now)
1 - Anubias barteri nana (started out ~3" long rhizome, now has 4 off-shoots each about 3")
Since all of this has grown well over the past year, even with my so-so, el-cheapo lighting, I decided to add a few higher-demand plants and try my hat at those for awhile. With that in mind, I added the following within the past month:
3 - Echinodorus tenellus (already sending out runners)
2 - Hygrophila polysperma ( I was told... brownish stems make me think it might actually be corymbosa sp.?)
2 - Ludwigia repens
2 - Rotala indica
Throughout this first year of my foray into plants, this has been my fert/supplementation regimen:
50% water change weekly
daily dosing of Seachem Flourish Excel at the recommended dosage
every 3rd day, dose Seachem Flourish Iron
every three months, insert 5 flourish tabs into the gravel bed
Despite all of my good experience with slow, sustained growth, I have wanted to get into CO2 dosing (was intrigued by it 15+ years ago) while keeping my main goal of a nice planted tank on a budget. After finding this site and a couple of others, I decided on a 2-liter bottle DIY CO2 system and completed my new set-up just two days ago. I'm using the Nyberg yeast method and injecting the CO2 directly into the intake for my Fluval which seems to be doing a fine job at chopping the CO2 into lots of very fine bubbles. After 48-hours, the bubble rate is ~15 bpm which seems pretty consistent with reports from others I've found online.
Much to my surpise this afternoon when I returned home from work, I found that almost all of the plants were pearling and the large mother echinodorus has steady streams of oxygen bubbles coming from the tips of several leaves!!!
I did not expect to see results like this quite so fast but I am very pleased that I am.
My two main questions are this:
1) With the addition of the CO2, I anticipate healthier plants and faster growth rates; how quickly should I anticipate I will need to modify my supplements to compensate for the added uptake (or will I need to at all)?
2) Is my current lighting sufficient to sustain healthy yet controlled growth long-term, or should I consider getting one of those AHSupply 55W bright kit conversion kits with 55W PC lamp and parabolic reflector?
Thanks again for a great site and thanks in advance for your replies.
-Jimbob
Fish include:
1 - pleco
2 - clown loaches
2 - Ludwigia repens
2 - Rotala indica
-Jimbob
