Well after testing this design for the last month after final tweaking (learning from mistakes) I feel comfortable posting this. Plus it may spur other ideas on CO2 diffusion
I tried all kinds of methods for diffusing CO2 in my 150g tank. Misting wasn't an option since the soda bottle look wasn't pleasing to me. I tried DIY pvc units with different pumps and all of them used way to much CO2 and were not consistent enough to my likings.
So while wander Home Depot for ideas I came across GE's SmartWater filters and figured what the heck it might work and will give me extra water filtration. Thus making the diffuser a dual purpose unit.
I found that using to units inline with each other. 30 micron poly spun in the first, and 10-15 micron in the second worked quite well. Main problem was that as they clogged CO2 diffusion decresed due to the loss of flow. So I then tried a heat drilled .5 inch hole in the bottom of each filter hoping I wouldn't loose the filtration aspect. This worked fine for the 300gph pump. But I wanted to get rid of the powerheads from the tank, so I hooked up a Mag 9.5, and then found that a .25 inch hole worked much better to balance the CO2 diffusion and filtration to best levels.
I replace the 30 micron every three weeks, the 10-15 micron lasts four to six depending on how well I vacuum each week at water changes.
The added benefit is if you ever get cloudy water you can throw in a .5 micron normal or .5 micron carbon pleated filter in the last stage to quickly polish the water.
The replacement cartridges are relatively cheap and vary in price. Home Depot 2 packs for $7 - $10, Ace Hardware just about the same as Home Depot but I find their 30 micron is much thicker and lasts longer before the core begins to discolor, and WalMart $4 - $6 for 2 packs. I found the Walmart filters to last easily half as long before the cores show discoloration but they are a cheaper short term option.
Obviously the pump size, size of hole in filter, cleanliness of tank will all play a role in how long each filter lasts.
My current bubble rate is 6 bps to keep the tank at a constant green/yellow per the 4dkh drop checker. 4bps keeps the tank at a good forest green. But the fish show no signs of distress at the current levels.
This is a pic of the filters after three weeks of use
