Disodium hydrogen phosphate dosing
nipat
May 23, 2009
665
Please confirm my calculation, does 150 mg of Na2HPO4 give about 1.25 PPM of PO4 in 80 liters of water?
Well, recently it seems the only place in Thailand I know that sells KH2PO4 in small amount
has closed down. The other convenient choice is it.
PS: Please don't suggest switching to Fleet Enema.... :)
Philosophos
1,346
=94.973/141.96*150/80
=1.254398245984784
Yup, you're good.
Definitely no sense buying fleet enema if you've got pure Na2HPO4. Heck you could even sell your own home-made enema kits to other people :D
Philosophos
1,346
Not a thing if you don't count expense; the cost is 3-4x as much for the same quantity of PO4 shipped to your door in the form of KH2PO4. This is assuming you only order 1lb for $2-4 plus the $6 flat rate shipping, which usually allows for up to 3lbs if I'm not mistaken.
787
If you can get things from SG, then Dr Mallick's is good for most items.
Order some and get a lot in.
Then you will not run out for years:)
nipat
May 23, 2009
665
Thanks, Dan. :)
I'm afraid I can't. Unless they (Dr Mallick's) would label it as something else.
Importing chemicals that falls into fertilizer category is still troublesome.
Actually the info is for telling people here where to buy PO4 if they're interested in EI.
My 1 kg bag of KH2PO4 still doesn't look depleted a bit. :)
A goose with a gush....
My Goose Gushed
Hi Nipat, All,
Never would I recommend Fleet Enemas, well okay I might. :p
The Wal-Mart knock-offs run under US$2.00 for 236-ml, that is a year’s supply for an 80-gallon tank, all mixed, easy to measure and so far no government restrictions on them. :)
At least no restrictions until the teens and college kids figure out some "off label" use for the stuff... :)
C
csmith
Biollante;48754 said:
Hi Nipat, All,
The stuff really works. I haven't seen GSA in a few weeks now.
I can see the news story now. "He snorted what?!"
