Mounting and cooling LEDs
LEDs require a heat sink to keep them from overheating and destroying themselves. For a big light fixture, a heat sink made from aluminum channel extrusions, bolted side by side to give the width needed, works very well, and is much less expensive than finned heat sinks made for that purpose. It is helpful to use about 1/8 inch thick aluminum spacers between the channels to provide space for cooling air to flow around each channel.
After bolting the channels together, use silicon carbide sandpaper wrapped around a wood block to sand the faces flat, and polish them with finer grades of silicon carbide paper. The objective is to get as perfect a contact between the LED “star” mountings and the heat sink as is possible.
The “star” mountings have notches around them to allow holding them in place with #4 size screws, and flat head screws, normally countersunk, are the best type of screw for this purpose, because they cannot accidentally contact the very close by solder pads on the “star” mounts. Drilling and tapping the holes to fit #4 screws is very easy, using a cordless screw driver or drill.
EDIT: Apparently the star circuit board the Cree LEDs are mounted on do not insulate the center aluminum layer very well at the edge where the mounting notches are located. Using flat head screws can cause current leakage to the heat sink, which should be grounded, and shut down the light. It may be much better to use an adhesive thermal conductive material to mount the LED stars on the heat sink, and omit the screws.
First mark lines along the heat sink where the LEDs will be located. Then mark a spot 3/8” (9.5 mm) on each side of that line on the centerline for each LED. Use a center punch to make a small indentation on each mark. Drill a 3/32 inch diameter hole through the heat sink at each location. (Extreme accuracy is not needed.) Use the cordless screw driver, or cordless drill with speed control, to slowly tap the hole with a #4-40 tap. It works best to turn the tap a few times, back it off to remove the aluminum particles from the tap, then finish tapping the hole. Working with aluminum is much easier than working with steel, so it is very unlikely that you will break the tap.
Use silicon carbide paper, a fine grade, to flatten the areas where the drilling and tapping raised the metal, and polish again with finer grade paper. Clean the heat sink surface with alcohol until no more powdered aluminum rubs off.
To get better heat transfer between the LED “star” mounts and the heat sink, use a thermal compound on both the heat sink surface and the back surface of the LED. There are now many such compounds available, but one of the best for the money is Antec Formula 5, which comes in a big enough tube to mount about 50 or so LEDs. Fry’s Electronics stocks it. Use only a tiny amount on each surface, a dot of the compound, spread a little with the nozzle of the tube. Rotate the LED slightly as you lay it in place to further spread the compound, and attach the LED with 1/2” long #4-40 flat head screws. (The length of the screws isn’t important, but needs to be long enough to handle easily.)
The heat sink will slowly get hotter and hotter, with the light fixture on, unless a cooling fan or fans are used to help transfer the heat to the air. Mounting the fans above the heat sink, blowing down on the back of it, works fine. This gentle cooling breeze will also help keep the AC-DC converters and voltage regulators cool, if they are mounted on or above heat sink.
Use short lengths of 22 gage insulated wire to connect the LEDs in series, in groups of 3, for this particular design, and longer lengths to make the parallel connections behind the heat sink. Soldering is easiest using a solder with a small amount of silver in it, and resin core,
Silver-Bearing Solder (1 Oz.) - RadioShack.com plus a small soldering iron,
15-Watt Soldering Iron with Grounded Tip - RadioShack.com
You now know just about all that I know about making a relatively cheap LED light fixture. Try it. It's fun!
