Definition of Low Light vs High Light
Discussion in 'Lighting' started by catchnrelease, Jan 22, 2016.
  1. catchnrelease
    catchnrelease Junior Poster
    Jan 19, 2016
    14
    2:20 AM
    I have another newb question. If I have a 75g tank and one Archaea 120cm Planted tank LED light(Aqua Forrest Aquarium sells them) resting close to the glass in the center of my tank which I just started using the dry start method. I am at 10hrs/day with the MC that I just planted and planning on that for the next 4-8 weeks. So is the low/high based only on watts/gal or also on amount of time? Am I on the right track? Do I have low or high light?
  2. catchnrelease
    Jan 19, 2016
    14
    2:20 AM
    PS. How should I deal with the mold on the wood I am creating with this humid environment? The wood is now part of the substrate (can't take it out). Thanks
