Cycling advice
Discussion in 'Are you new to aquatic plants? Start here' started by AtticusFynch, Sep 15, 2017.
  1. AtticusFynch
    AtticusFynch New Member
    Sep 7, 2017
    26
    5:13 PM
    So I'm in the middle of cycling my first tank (pic attached). I'm about 3 weeks in. I'm using Amazonia, which has been my ammonia source, and it's decently planted.
    Ammonia has held steady at about 4 ppm for a couple of weeks now, despite water changes every other day or so. I started seeing nitrates about a week ago, but (oddly) no nitrites. There are no nitrates in my tap water.
    Today, ammonia hit zero for the first time. Nitrites suddenly appeared, about 5 ppm, and nitrates are sky high - 80 ppm.
    So my question is, what now? Do I do a big water change and see if nitrites come back? Or wait for nitrites to hit zero, too? If the latter, do I need to start supplementing with ammonia now that that's at zero? I don't want the ammonia consuming bacteria to die off, but I also suspect the aquasoil is still leaching, they're just consuming it all.
    Any advice?
  2. Phishless
    Phishless Lifetime Member
    Jul 13, 2017
    1,116
    969
    8:13 PM
    High NO3 will stall the process.
    I'd recommend a WC.
  3. Dennis Singh
    Dennis Singh SynKing!
    May 5, 2013
    2,417
    639
    5:13 PM
    you using tap water?
  4. AtticusFynch
    Sep 7, 2017
    26
    5:13 PM
    Yes, using tap water. My tap water has no nitrates though.
    I'll do a wc - thanks for the advice.
  5. AtticusFynch
    Sep 7, 2017
    26
    5:13 PM
    Ok, did a big wc last night. This morning, nitrites are about 3 ppm, nitrates down to 20, still zero ammonia.
    So, should I supplement with ammonia? Or just wait for nitrites to hit zero?
  6. Dale Hazey
    Dale Hazey Junior Poster
    Feb 18, 2017
    165
    144
    1:13 AM
    I'm no expert but, I wouldn't add any ammonia. I thought aquasoil leached ammonia for a month or two?
    I'd wait for nitrites to hit zero.
    Tom Barr September 2006 Barr report
    Do not use “fishless cycling” with ammonia in planted aquariums
  7. VaughnH
    92
    1:13 AM
    Diana Walstad has reported data that shows that aquatic plants use ammonia as a source of nitrogen before using nitrates. That means you can start a tank by first planting it heavily, then getting the plants to start growing, then adding a few of the fish you want every week or two until you have added all you want. I have done this many times, and it always worked fine, although I didn't know why it worked so well. My current tank I did a "fishless cycle", but only added a trace of ammonia, not the big doses usually recommended by those who like "fishless cycling". That worked ok too, but was a lot of added work.
