Cyanobacteria in my non co2 tank
Discussion in 'Non-CO2 Methods' started by gabcas0319, Aug 29, 2016.
  1. gabcas0319
    gabcas0319 Junior Poster
    Aug 29, 2016
    78
    8:30 AM
    Hello! y have a 5gal non co2 tank! my water parameters are
    PH: 8
    KH:6
    GH:7
    nh4:0ppm
    NO3:10ppm
    PO4:1ppm
    light 2w/gal
    and i have cyano :( what is the cause of it? :(
    Please help
  2. Apprentice
    Apprentice Lifetime Members
    Feb 4, 2015
    61
    6
    8:30 AM
    Hi gabcas0319. Cyanobacteria can either be the result of too little nitrates in a planted aquarium leading to plants leaking organics in the water column. In your case with 10PPM nitrates not likely the cause. More likely just excess organics from other sources. Decaying leaf litter, fish waste, excess food and or lack of maintenance.
    Also low oxygen levels can contribute to this. Filter flow low. May need cleaning. Excessive temps due to summer heat. Also make sure no direct sunlight is hitting tank.
    I would manually remove / siphon off as much cyano as possible. Do a good all around cleaning of tank and filter. Prune any weak or dead leaves from plants. Light gravel vac. Water change and dose nutrients.
    If heat is also an issue try fan blowing over top of tank. Works fairly well at reducing temps.
    The fact you still test at 10PPM of nitrate indicates you don't have a super bad case. Really bad cases of cyano will zero out nitrates. Severe cases may require spot dosing with H202 or dosing erythromycin. You should not need this. Manual removal of cyano, pruning, maintenance, keeping temps down and water changes should take care of it. Let us know how you make out on this issue.
    Regards, Rob
    2 people like this.
  3. gabcas0319
    Aug 29, 2016
    78
    8:30 AM
    Thanks for the help Rob. today i make some changes to the tank, i lower one pump to the medium of the tank also i add a small air pump siphon the gravel clean the filters and add more no3! the question is my temperature stays at 77 degrees it is too hot? thanks
  4. Apprentice
    Feb 4, 2015
    61
    6
    8:30 AM
    77 deg. is fine.
  5. gabcas0319
    Aug 29, 2016
    78
    8:30 AM
    Thanks Rob!!! :D :D:D:D
  6. Apprentice
    Feb 4, 2015
    61
    6
    8:30 AM
    Your welcome.
  7. Pikez
    Pikez Rotala Killer!
    Staff Member Moderator
    May 12, 2013
    1,962
    1,473
    8:30 AM
    Dang good advice.
  8. Adam Edmond
    Adam Edmond Junior Poster
    Oct 25, 2016
    21
    8:30 AM
    Low nitrate levels or not enough circulation often seems to get the blame.
