Anyone tried it? I'm wondering if it'd be stable, and which order to combine them in. I know the MgSO4 needs to go before the CSM+B, but I'm not sure where the CaCl2 would fit in.
-Philosophos
-Philosophos
Philosophos;40269 said:The CaCl2 being compatible with everything in CSM+B was my main concern. I wasn't sure of the complete list of compounds that goes in to CSM+B, and I've had enough fun with CaCl2 creating precipitates.
Anyhow, thanks for the advice. I'll be testing things out in the next few days.
-Philosophos
Biollante;41029 said:Hi Singtoh,
Generally, we add the MgSO4 to the macronutrients, though I am not sure, there is any reason not to add to CSM+B. I have heard rational, but I was a PMDD sort for many years and saw no ill affect from rolling them together.
I would continue to add the MgSO4 (most likely MgSO4.7H2O), I suppose there is no great need to add any Calcium, such as CaMg(CO3)2. Though odd as it may seem I would still add a little GH booster at each weekly water change.
As long as you are doing 50% or better water changes every week you will be fine and sure that you are not limiting anyone.![]()
I am not sure I understood the “I have been adding 11 teaspoons to 1 liter DI water” part. Eleven teaspoons of what?
Biollante;41036 said:Hi Sintoh,
I don’t see any problem with mixing the Epsom Salt with the CSM+B, someone may have a reason but I don’t know what it is, I always put it off to custom or evening the daily dose over the course of a week.
I cannot see anything wrong with the arithmetic.![]()
I would at least double the dose of MgS04.7H2O, personally I dose much higher than that.
