Creating Fert solution from dry ferts
Discussion in 'Estimative Index' started by lcassidyjr, Jun 10, 2017.
  1. lcassidyjr
    lcassidyjr Subscriber
    Jun 7, 2017
    13
    12:13 PM
    Hi, Folks! I've been out of the planted aquarium game for a few years and found a Betta that forced me to set up a small planted tank for him. I'm getting ready to mix my ferts and had a question about Wet's calculator.
    I'm going to do a low light EI schedule and when I went to calculate my solution I noticed that I can only do one fert at a time. KNO3 and then KH2PO4. If I mix both doses in the same solution will this throw off the dosing? Or do I need a solution for each macro? In the past I mixed them together but can't find my calculation notes to see if each fert was adjusted for the combination.
    Also, Using Tom's lowlight EI method, do I need to use K2SO4 in addition to the KNO3 and KH2PO4? or will just those two work?
    Thanks for the help, everyone.
  2. Christophe
    Christophe Subscriber
    Oct 3, 2013
    395
    269
    12:13 PM
    KNO3 and KH2PO4 are fine to combine. The only thing to consider in mixing them is that you get potassium from each. Since you'll likely use a lot more KNO3 than KH2PO4, most of the K is provided by it.
    In low light, low-demand systems, you'll most likely get enough K without needing the sulfate.
  3. lcassidyjr
    Jun 7, 2017
    13
    12:13 PM
    Thanks for the feed back. it's all starting to come back slowly, haha.
  4. geektom
    geektom Junior Poster
    Dec 16, 2012
    351
    326
    12:13 PM
    I hope you don't mind me jumping on here- I am trying to figure out the same things.
    The tank will be: 20 US gallon regular, CO2 injection, medium light (24" Finnex FugeRaye Planted +), fully planted (semi-dutch)
    According to the rotalabutterfly calculator, from the EI dry ferts kits I purchased from Green Leaf Aquarium (I figured it was a good way to learn), my dosing will yield the following:
    KH2PO4:
    PO4 1.3 ppm
    P .42 ppm
    K .54 ppm
    KNO3:
    K 4.73 ppm
    N 1.69 ppm
    K2SO4:
    K 7.5 ppm (?!?)
    S 3.08 ppm
    This means that totaled together, I will be at 12.77 ppm of K- is that right? Am I supposed to be taking into account how each compound adds more K?
    Just when I thought I was figuring it out, now I am really confused again.
  5. Julia Adkins
    Julia Adkins aquariumfertilizer.com
    Jun 22, 2015
    172
    42
    12:13 PM
    That's a pretty heavy dose of phosphates along with a heavy dose of potassium. You would do well to reduce those and get some magnesium and calcium in the mix along with some micro nutrients.
    geektom likes this.
  6. geektom
    Dec 16, 2012
    351
    326
    12:13 PM
    Thanks, Julia- I am dosing micros on T/Th/Sat using Green Leaf Aquatic's "CSM+B" formula.
    Seeing as I am using the calculator everyone recommends, how should I determine how much to reduce?
