CR500
Recommended Tank Size: Up to 60 gallons
Media Capacity: 2 gallons
Dimensions (L x W x H): 16" x 8" x 12"
Inlet /Outlet (bulkhead): 3/4" / NONE
Internal Sump (L x W): 7 1/2" x 7 1/4"
CR900
Recommended Tank Size: Up to 125 gallons
Media Capacity: 4 gallons
Dimensions (L x W x H): 21" x 10" x 15 1/2"
Inlet/Outlet (bulkhead): 1" / NONE
Internal Sump (L x W): 9 1/4" x 8 3/4"
CR1000
Recommended Tank Size: Up to 150 gallons
Media Capacity: 5 gallons
Dimensions (L x W x H): 20" x 12" x 15"
Inlet/Outlet (bulkhead): 1" / 1"
Internal Sump (L x W): 11" x 7"
The value of a biological filter depends on how well it performs the tasks
of oxygenation, ammonia conversion and gas exchange on a long term
basis. In the wet/dry filter, air and water mix as water trickles over the
exposed filter media, Bio Bale. Biological filtration and gas exchange
occur as the water flows in a thin layer over the media surface. CR Series
filters provide optimum growing conditions for bacteria that oxidize nitrite
and toxic ammonia. The rapid oxidation of ammonia and nitrite helps to
maintain a stress free environment for aquatic life. CPR filters are
designed for long-term reliability and ease of maintenance
Simple in concept, Bio-Bale owes its extreme effectiveness to its high surface area
versus volume and its unique surface texture. With 250 square feet of surface area
per cubic foot and 33 square feet per gallon, Bio-Bale cannot be matched. Bio-
Bale is produced from one continuous piece of F.D.A. approved, non-toxic plastic
designed specifically for CPR. Bio-Bale is measured precisely by computer to
achieve a consistent surface area.
CR2000
Recommended Tank Size: Up to 200 gallons
Media Capacity: 1 cubic foot
Dimensions (L x W x H): 24" x 12 1/2" x 20"
Internal Sump (L x W): 11 3/4" x 10"
CR3000
Recommended Tank Size: Up to 400 gallons
Media Capacity: 2 cubic feet
Biological: 27" x 13 1/2" x 18"
Sump: 20" x 12 1/4" x 18"
Inlet/Outlet (bulkhead): Two – 1" / 1"
