Counting bubbles per second
Discussion in 'CO2 Enrichment' started by barbarossa4122, Mar 17, 2011.
  1. barbarossa4122
    barbarossa4122 Guru Class Expert
    Dec 29, 2009
    975
    7:09 AM
    How can I count more than 3 bps say, 4 or 5 ? I tried 5 seconds time frame and 10 seconds time frame and it's impossible. I noticed on other forums ppl claiming that they use 4, 5, 6 even 8 bps. How the heck do they know since imo, it's impossible to count ?
  2. Gerryd
    Gerryd Plant Guru Team
    Sep 23, 2007
    5,624
    7:09 AM
    I would say they are guessing unless using video and the pause and slow motion functions :)
  3. barbarossa4122
    Dec 29, 2009
    975
    7:09 AM
    I was advised to use a metronome and I think it will work. Will find out tomorrow morning.
    Great idea with a vid camera but, don't own one.
  4. Gbark
    Gbark Guru Class Expert
    Jun 15, 2009
    266
    7:09 AM
    i waste a lot of co2 and have my bubble rate high, infact i could not tell you what it is as its so fast. :)
  5. Jim Miller
    Jim Miller Lifetime Charter Member
    Oct 31, 2010
    449
    7:09 AM
    I'm having trouble understanding why you would need to count that high. What is your tank size and diffusion method?
    If you really need some way to increase the rate without counting bubbles perhaps you'd be interested in my latest project. A linear increase in CO2 output from 0.1pps to 5pps with a 270* turn of a knob. See the bottom of my last blog post for some details.
    Jim
    #5 Jim Miller, Mar 18, 2011
  6. barbarossa4122
    Dec 29, 2009
    975
    7:09 AM
    Hi Jim,
    The tank is a standard 55g. Right now I am using a 60mm GLA atomic diffuser at 3bps. I am just curious about this since some folks claim they use 5 or 6 bps. I am sure they are not lying but, how do they count with the naked eye.
    #6 barbarossa4122, Mar 19, 2011
  7. Left C
    Left C Lifetime Members
    Sep 26, 2005
    2,510
    7:09 AM
    Would timing how long it takes for the CO2 to fill up a specific volume be useful? This is another way to calculate the rate. Here is an idea.
    I thought about using a small coffee tin with its removable plastic lid and a balloon. I have a 13oz coffee tin. I can use water and a graduated cylinder to find its volume. I would need to make a small hole in the lid for the CO2 tubing and the balloon goes inside the tin.
    Push the tubing through the hole in the lid and secure the balloon onto the end of the tubing. Put the lid on the coffee tin with the balloon inside. Turn the CO2 on while timing it. The balloon will fill up with CO2, but it can't get any larger than the volume of the coffee tin. When the CO2 stops going in, note the elapsed time. You will know that the CO2 has stopped when there are no more bubbles going through the bubble counter. You can calculate the milliliters per minute or per second or whatever way that I want to express it.
    What do you think? Something smaller than the 13oz tin may be better.
  8. ibanezfrelon
    ibanezfrelon Guru Class Expert
    May 18, 2010
    205
    7:09 AM
    I can count up to 7bps, i guess guitar playing and practicing with the metronome for years makes it easier
  9. Jim Miller
    Oct 31, 2010
    449
    7:09 AM
    PV=nRT. How will you measure "P"?
    Jim
  10. Left C
    Sep 26, 2005
    2,510
    7:09 AM
    Good question.
    The regulator has a pressure gauge. Let's say that it is set on 10 psi. When the pressure equalizes with the balloon in the coffee tin, the CO2 stops flowing. The pressure in the balloon would be 10 psi too. We would have the volume and the time that it took to equalize (stop flowing). This would give us mL/sec or whatever units of measurement that we want to use. In other words, the pressure is redundant. Whatever pressure that we have the regulator set at, the balloon would have this same pressure when it equalizes and stops flowing. (Unless it is set very high and it blows up the balloon and the coffee tin.)
    We can check it by putting a "T" in the CO2 tubing with a fitting to measure the pressure with a tire pressure gauge or something similar.
    The "Ideal Gas Law" is a good approximation of a gas that behaves as an ideal gas under many conditions. My suggestion is a good approximation of the CO2 rate.
    #10 Left C, Mar 24, 2011
  11. Jim Miller
    Oct 31, 2010
    449
    7:09 AM
    Lack of coffee prior to posting...
    Looks like a good strategy. Give it a go!
    Jim
  12. Matt F.
    May 30, 2009
    2,319
    7:09 AM
    Left C, are you sure you didn't do anything more than coffee? Nicotine, when I smoked, helped me with creative thought, but this is very interesting! ;)
  13. Left C
    Sep 26, 2005
    2,510
    7:09 AM
    Just two cups of coffee and no nicotine. It's just an idea that popped up. It sounds rudimentary or like something made in Frankenstein's basement. I was thinking of something cheap and easy to try.
  14. Jim Miller
    Oct 31, 2010
    449
    7:09 AM
    wouldn't it be a hoot if it turned out the amount of co2 was conveniently measured in
    micromoles!!!
    jim (per unit time of course...)
  15. Left C
    Sep 26, 2005
    2,510
    7:09 AM
