Coralline Algae lighting
Discussion in 'Marine Plants - Macroalgae' started by feh, Feb 3, 2012.
  1. feh
    feh Guru Class Expert
    Jan 14, 2011
    669
    2:17 PM
    Whats considered too much light for coralline algae?
  2. Biollante
    Jun 21, 2009
    2:17 PM
    What Little I Know...
    This is not something I have a lot of experience with, but this is my experience and what I think I know.
    I understand that it rather depends on the species, generally though that it does well in low to moderate light, preferring the blue end of the spectrum. That high Calcium and low phosphates are important.
    In my FOWLR Coralline algae grows abundantly and colorfully in rather low light. I didn’t choose the Coralline algae it came in, I assume on the live rock. So for all I know if I had high light maybe another type would grow.
  3. feh
    Jan 14, 2011
    669
    2:17 PM
    Water parameters are fine. As for N03 and PO4 - probably a little too clean. I have it growing on my rock, but was wondering if it needed more or less light. I did some research on it and read pretty much the same as you're saying. Spose I won't blast it with 6 T5HOs to keep it growing. So far I've been fortunate with its grow and its only on my rocks, but I do keep my overflow / glass regularly. I personally don't like the look of the back glass and overflow covered in it. I purposely "infected" my rock with with it using some rubble. Same rubble I used to seed it with bacteria. Thanks for the feedback though. I just wanted to maintain the growth and keep it growing until I start tossing in other stuff that will require more light.
  4. Tom Barr
    18,691
    711
    2:17 PM
    Coralline algae is easy if you add moderate to high light,. I'd say the range is massive....but need the Alk and Ca++ high and the PO4 low.
    Wait and you shall have more than you want.
  5. feh
    Jan 14, 2011
    669
    2:17 PM
    PO4 still reads 0.00 / 0.01 with practically no other algae in the tank. Alk is 136, Ca 430, Mg 1487. What I've noticed though is all the light its been getting is either from testing water parms with lights on or cleaning glass and so on. Beyond that it is a bright room during the day and seems to be growing fairly well on one side of the tank. The other side not so well. The side that is growing faster is closer to the windows but its not exactly direct light.
