Converting standard to rimless.
SylvesterGraham
Apr 22, 2012
10
Boston, ma
Hello,
I've recently come across a 90 gallon Craigslist tank. I'll be getting it either way, but, unfortunately, it isn't rimless and what's worse the frame is covered in that plastic faux wood veneer.
Has anyone ever tried to remove the framing on a standard tank, leaving only the glass behind. I'm sure someone has, but my searches came up empty. I imagine a little extra silicone and bracing would be I order... But what do I know.
Sylvester
ShadowMac
1,043
13
Grand Forks, ND
I've heard of it being done on a 10 gallon...maybe even 20 gallon, but I wouldn't suggest it for a tank that size. The frame holds the tank together and the seems would likely give out, even with some added bracing.
I wouldn't do it.
SylvesterGraham
Apr 22, 2012
10
Boston, ma
OK, that makes sense.
But the glass is still there, and at least part of it is held together by silicone. Why not just strip the frame and silicone and "start over" with the pre-sized panes of glass?
I am no structural engineer, but I'm no hack, either. I understand a higher water column is what creates pressure, instead of just volume. If I were to do this I would build a jig for assembly, buff and polish the glass ends to avoid micro cracks... etc. I have built a 15 gallon from scratch as well.
ShadowMac
1,043
13
Grand Forks, ND
I think the rimless tanks use a higher grade silicone to hold them together. The larger ADA tanks still bow a little bit. I can't provide any advice on assembling such a thing. I bet you could find some tank build threads for the type of thing you are looking for on some of the reef forums. A lot of guys building things over there. I'm sure someone around here has done something, but I haven't seen any build threads that started with 4 glass panes.
SylvesterGraham
Apr 22, 2012
10
Boston, ma
Thats a good idea about the tank build threads.
If there's considerable danger doing this, even if it's done in the best way possible without industrial equipment, I'll probably just suffer the molding. A tank failure is so catastrophic...
