Thank you for that reply, as I think about i think my problem might be precipitation or contaminates? My past recipes (copied from my recipe book) are as followed:
3-13-23 EI Macro
Stored in Green Nilocg 500ml bottle with 1ml pump.
Kno3 – 58.2g, K2HPO4 – 11.4g, 500ml Purified H20, 10ml Ez carb
A dose of 1ml per 2.5g every other day will add
NO3-7.4ppm, PO4 -1.29ppm, K-5.72ppm.
Do a 50% water change & add GH Booster on Sundays,
Repeat the process starting on Monday
3-13-23 EI Micro
Stored in Brown Nilocg 500ml bottle with 1ml pump.
CSM+B – 36.7g, 500ml Purified H2O,10ml EZ Carb
Dose 1ml Per 2.5g every other day, alternating between Macro
And Micro
****This mix was fine just too small of a dose for larger tanks******
5-17 PPS-Pro Macro
Stored in Nilocg 500ml dosing bottle.
Kno3 – 19.7g, K2HP04 – 1.8g, K2S04 – 17.5g
MgS04 - 12.4g, 296ml H2O, 6ml Ez Carb
1ml per 10g at lights out, daily
Dose will add:
NO3-1.06ppm, PO4 -0.09ppm, K-1.44ppm
S-0.42ppm, Mg-0.11ppm, dGH-0.02
5-17-23 PPS-Pro Micro
CSM+B – 17.2g, 296ml Purified H2O, 6ml EZ Carb
Dose 0.5ml Per 10g daily while lights are off
***This dose was fine, I just didn't like the PPS-Pro method***
8-04-23 EI Macro
Stored in 1L Polar Seltzer water bottle with non close-able 2ml pump head.
Kno3 – 118.0g, K2HPO4 – 23.0g, Mgso4 - 25.0g, 500ml Purified H20, 10ml Ez carb
A dose of 2ml per 10g every other day will add:
NO3-7.50ppm, PO4 -1.30ppm, K-5.27ppm,
Mg-0.26ppm, S-0.34ppm, dGH-0.06
This is the batch that im having trouble with which seems to be less concentrated than previously calculated. Could the problem be how I'm storing it rather than the recipe its self?
