Hi everybody,
I'm a little confused...
and this is the best place to turn for help.
I recently purchased a CO2 drop checker from Redsea. It seems to work well enough, but unfortunately I'm not certain that I'm getting an "accurate" result (well as accurate as possible with a cheap test anyway).
When I look at articles about DYI drop checkers, it is often mentionned to use a 4 dkh buffered solution + somekind of standard PH reagent solution.
The manual that came the Redsea's product mentions that I should use 1ml of water from my tank + 2 drops of their PH reagent.
Maybe I'm splitting hairs here. The drop checker is basically a PH test, but since PH can be affected by both the quanties of dissolved CO2 and the KH of the water, the only way to get an accurate result should be to use a buffered solution. Right?
/This could explain why the people wirtting the manual "forgot" to indicate blue=x ppm, green=y ppm and yellow=z ppm.
//I guess than mentionning that "You need to make your own buffered solution for it to work properly... suckers" is not good marketing...
