Confused about dry 10% EDTA Fe dosing...
Discussion in 'Aquatic Plant Fertilization' started by pepetj, Jun 23, 2011.
  1. pepetj
    pepetj Lifetime Members
    Oct 8, 2008
    188
    3:31 PM
    I got a 1Kg package of dry chelated iron (EDTA Fe). The bag says it has 10% of Fe and the rest 90% is inert.
    Using Teaspoon-Tablespoon as measurement how should I dose? Is the 10% a standard presentation or a "diluted" one?
    I prepare solutions for my macros so 5ml is all I have to add per 20gals of water; can I go with similar solution for Fe EDTA at 10%?
    The package says to consult with a professional for dosing instructions...
    Pepetj
    Santo Domingo
  2. grshs_vny
    grshs_vny Prolific Poster
    Jan 12, 2011
    31
    3:31 PM
    10% is the concentration in presentation,not after dilution.1gram of 10% Fe EDTA increases iron concentration by 1ppm in 100liters of water.
  3. Biollante
    Jun 21, 2009
    3:31 PM
    Professional Potted Plant Consult, PayPal Accepted…
    Hi Pepetj,
    50 grams of 10% iron mixed into distilled water and top off to 500-mililiters will yield a 1%, or 10,000-ppm iron solution. :D
    Store in a dark place, those brown Hydrogen peroxide bottles are great, store them away from the light.:cool:
  4. Biollante
    Jun 21, 2009
    3:31 PM
    Response To Email Question... I Should Have Been Clear...
    Hi All,
    To clarify, I used the 1% solution to match SeaChem’s Flourish Iron.:)
    Each milliliter will raise the iron in 20 gallons of water about 0.13-ppm.:gw
