Complex Question - limewood airstone
Discussion in 'General Plant Topics' started by quenton, Apr 22, 2006.
  1. quenton
    quenton Guru Class Expert
    Mar 14, 2006
    170
    6:22 PM
    Now this is really complicated -- I suspect only this forum could answer it ;)
    Actually, that may be true, since lots of people here may in fact use one.
    How do I hold it down?
    In one tank I have a rock on it -- that seems to work. In the other I have it suck partly under some driftwood, but bubbles get trapped and come out as very large bubbles at times.
    So I was just curious what others do.
  2. PeterGwee
    PeterGwee Lifetime Charter Member
    126
    1:22 AM
    Re: Complex Question - limewood airstone
    Attach a suction cup to the CO2 line before the limewood stone and place it anywhere near a good current source.
    Regards
    Peter Gwee
  3. quenton
    Mar 14, 2006
    170
    6:22 PM
    Hey -- that worked!
    I drilled a small whole in the other end (offset to miss the whole that goes through it), shoved a plastic tube joiner in, put 1/2" piece of tube on it and put a suction cup on each end -- works really well.
    Thanks for the suggestion.
