Hi all,
As part of the process to introducing/acclimating some new fish to the display tank, I turned OFF c02 for the entire day today, and reduce the light considerably. So, it had been close to 24 hours with no c02 by the time the fish were introduced..
I couldn't help but notice how much different the rummies were breathing in terms of gill rate as compared to the SAME time when c02 is normally on....
They are more active as well, even though they are not sluggish at all.
Based on this observation, I am going to lower c02 gradually until the gill rate is CLOSER to normal, and then increase SLOWLY from there. I do not want to go much past that, but some will depend on plant growth.
That being said, MY FISH ARE MORE IMPORTANT than my plants, and if I can't introduce as much c02 as I need, I will simply change the plant species to match
I see no need to push the fish for the plants...I added some extra surface ripple and 02 to help when c02 is on from now on..by adjusting the mp40 and the eheim outlets...
Just thought that it may be worth a shot every now and then for folks to do this....
One day of non c02 if the tank is going well should not cause any lasting harm...Keep the light off that day too if you want and only use it for the observation period.. Just a rainy day to the plants....
The difference was readily apparent as I have a clear picture of the fish at various times of the day and their patterns...
Thanks for listening...
