Would the Atomic Co2 diffuser by GLA work with a clippard mouse solinoid? I can't remember the working pressure for the solinoid, it was either max at 100psi or 10psi. and the working pressure for the diffuser is 30 psi.
As long as the valve doesn't end with "-H" you should be fine. With no suffix, it's 100 psi or so max, with "-L" it's 50, I believe, and with "-H" it's 25.
So, for example, EV-2M-12 and EV-2M-12-L will work fine with an Atomic, but EV-2M-12-H won't.
All three of them will work fine at 25 psi or under.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
