Ok, so here is another stupid question. I recently went from using Reactors to a NW setup. Tank size is 155 gallons. I have the CO2 dialed in now where everything is right, however...
I use a 20# tank of CO2. In the past a full tank would last me about 3 months. When I changed over to the NW setup, the full tank lasted barely 30 days.
hmm... Can I really be outgassing/losing that much CO2? I have leaked checked everything (shut off the tank, primary and secondary gauges did not move with solenoids turned off for 30 minutes) and can find no leaks on any fittings. This leads me to believe one of two things. First, the tank was not filled correctly, or second, I am wasting a lot of CO2!
The tank is run off of 2 solenoids. The first one is a steady 4 bubbles per second through an electronic valve (CO2 Doser). The second is just a solenoid and needle valve. Both are plugged in to a timer that comes on 90 minutes before the lights-on for a total on-cycle period of about 11.5 hours/day. The outputs of both are fed into a single line that attaches to the NW pump inlet (mag 18 fractioning). Flow back to the sump is with a sealed overflow box, into a sealed wet/dry sump. When the system is running there is a ton of tiny bubbles throughout the entire tank.
I'm thinking of putting back inline a reactor chamber to maybe help dissolve some CO2 before it hits the open tank?
Ideas? thoughts?
Thanks.
Ideas? thoughts?
Thanks.
