I've been using the Hach CO2 test kit which uses Phenolphthalein solution at 0.1% as tritation reagent.
I wrote to the local distributor with some questions regarding impact of water parameters in this particular test (such as pH, KH, GH, Temp).
I have not received an answer so after waiting for a couple of months for this reply I though about asking you.
I realize this is likely an indirect way of testing for dissolved CO2 yet I'm hoping this is at least better than using drop checkers and the KH/ph charts.
I get readings as high as 45-47 ppm in some of my tanks after 4 hours of continuous-on photoperiod... is that value likely realistic or not? Most of my tanks are in the 36 to 41ppm range, according to these readings.
Thank you
Pepetj
Santo Domingo
Thank you
Pepetj
Santo Domingo
