CO2 Solenoids
inkslinger
Dec 15, 2007
370
I have an inline Aqua Medic M-Ventil Solenoid that works fine , but would like to connect a Solenoid to my Regulator with an brass adopter and install a needle valve to it. I have been getting info on the Clippard : MME-2PDS-D110 an the Burkert Solenoid 6011 and to find out they are both sold here locally, so i email the 2 stores to see if i can pick up at there location hopefully to save on shipping .
I would like to know if any one are using any of these two and how do you like them
inkslinger
Dec 15, 2007
370
Will i chose to pick up the Clippard Soleniod Valve: MME-2PDS-D110 for $19.70 at a local store that carry's Clippard Instrument products and i get to pick it up at the store. now i just need to pick up a 3 prong power cable . Does the Solenoid Valve have a pic on how hook up the power cable to it.
inkslinger
Dec 15, 2007
370
Will pick my Solenoid up today an i took it apart to see how the power cord will get in stalled ? Do you just twist the ends of the wires tight and push them into the holes an tighten the screws , can you dab the tips with solder .
Has any one installed a power cord to a Clippard Solenoid Valve and how did you do it ??:confused:
