CO2 solenoid valve
punky
Feb 24, 2007
19
Hi, I am using a solenoid valve with a timer to cut off CO2 during the night. During the day it operates for about 10 hrs straight. The solenoid gets hot .. does anybody give it a break to cool down during the day? Will it have its lifetime shortened?
Frolicsome_Flora
Jan 12, 2007
351
Dorset, UK
naa they just do that, dont worry about it.
86
Any solenoid valve made for this use should be designed to run for 12 hours or more at a time. My guess is that they all are.
BHornsey
125
61
Doncaster, UK
Hi, the only one I've found that doesn't get hot is the Aquamedic M-Ventil Pulse.
It uses a high pulse to slug it open, then just a holding current to keep it latched.
It just gets slightly warm after 10 hours.
The only downside is it's about 30% more expensive than the standard M-Ventil.
