CO2 regulator seal
scottward
Oct 26, 2007
958
10
Brisbane, Australia
Does anybody know if the CO2 washer (i.e. the seal between the regulator and CO2 bottle) is a standard sized washer or a regulator brand specific washer?
argnom
May 24, 2009
109
Montreal, Canada
It should be a standard size. You do have to get a regulator seal as far as I know, not just any washer, but they should be pretty standard.
Lets see if left c has something to add. He knows more about regulators than I do.
Left C
Sep 26, 2005
2,500
71
Burlington, NC
Why are you asking this question?
scottward
Oct 26, 2007
958
10
Brisbane, Australia
I have a Red Sea regulator and asked Red Sea how much a new seal will cost. They are about $3.50 AUD for a Red Sea one, but I notice that home brew shops also sell CO2 regulator seals for less than $1.
Will any seal fit?
Go to any Gas cylinder refill place, they typically will give some for free.
Ask when you get the tank refilled, they have to be standard sizes, otherwise you'd have to use their special gas tanks and regs, and it would very hard to find someone to refill their special CO2 tanks:p.
They usually provide it, but if not they're cheap enough to replace each time. I suppose you could flip it over for the next use to try and even things out a bit...
scottward
Oct 26, 2007
958
10
Brisbane, Australia
I found a 'CO2 washer' on a website with the inner/outer diameter, outer diameter was about 19mm, inned diameter (i.e. diameter of the central hole) was only about 5-6mm. The inner diameter of my CO2 seal is 10mm. Is it possible that Red Sea have made their regulators so that only one of their CO2 seals will fit? ;-)
ibnozn
Mar 7, 2008
46
I have the same problem with my Tunze regulator. Standard replacement washers don't fit it for the same reason you seem to be talking about. I just use a rubber washer instead. Found it at Ace Hardware I think and I doubt it's meant for CO2. But it fits—and it works. :)
As long as you replace it with the tank you should be fine. If it's not meant for CO2 then over time it could degrade and break down and cause leaks. If you replace it each time you should be OK.
