Fishgovno;11610 said:
I saw your DIY reactor (Tom's)
Curious if you can explain why there is no media (bio-balls,foam,etc) in the reactor/bottom of your reactor?
I was under the impression that it is needed to help dissolve/mix water and Co2?
No, those other folks designed the inflow directly downward etc and think that it's best to save every last drop of CO2.
They also designed their reactor off mine and then questioned my design
I made the reactor so that you spiral the water downward and this produces a gentle outflow out of the bottom, no sponge is needed, these are ugly/distracting and often pop out over time.
Ask folks, they will tell you.
I make things myself, I watch and tweak things, rather than assuming so much about devices and methods, I look at them for their ability to perform the job.
Allowing the mist to flow downwards out the bottom and up through the plant leaves seems like a better idea than the sponge, but the effectiveness is really what counts. It's also easier to make and nicer to look at and watch.
