I am using a Duetto multi filter about an inch below the surface and it creates a small whirlpool mixing air into the water flow. The result is a constant misting. Could this be increasing the levels of CO2 or have I added a bubbler inadvertently? I am thinking of making a DIY internal reactor based on this idea. A sort of surface skimmer with injected CO2.
It would be 1 inch diameter glass tube, 15" total length, folded twice to give it a smaller foot print. The pump will be under the tank. So, one 3/4" line running to the pump and another one or two lines running back to the tank. Any thoughts?
