CO2 pH probe adaptation - DO Membrane
underwurlde
Dec 26, 2006
21
54
UK, Hants. New Forest
Possible cheap alternative?....
Some years ago I designed into one of my products a GoreTex hemetic sealing vent. It lets a sealed enclosure 'breath' while at the same time keeping it sealed against water ingression. The product within the range available that I used was a little 12mm diameter disk, with an adhesive ring on one side - you simply stick it over a hole. Part [HASHTAG]#GAW1020613[/HASHTAG]. Now because these little disks were only 40p a pop, it got me thinking - could this be used for the DO membrane?
See:
Sensor Protection
Designed for Typical Applications such as:
Hazardous Gas Sensors
Odor Sensors
Oxygen Sensors
Liquid Level Sensors
Pressure Sensors
Electrochemical Sensors
Gas Detector Monitors
http://www.gore.com/MungoBlobs/167/313/membrane_vents_GAW_101.pdf
Protective Vents (Waterproof to IP67) - Available as adhesive disks:
Adhesive and Cut Parts
Protective Vents - Complete Product List
I wonder if samples are available via the W.L. Gore & Associates web-site - I'm sure I managed to get some. :rolleyes:
Andy
88
Thanks for the tip. That product looks promising, especially the adhesive ones. When I get back to playing with this idea I will look at this more.
