CO2 not fully degassing
Discussion in 'CO2 Enrichment' started by SingAlongWithTsing, Apr 14, 2017.
  1. SingAlongWithTsing
    SingAlongWithTsing Junior Poster
    Feb 17, 2016
    145
    154
    1:07 AM
    So I recently checked my parameters today after switching from a wet/dry sump to a filter sock set up for a week
    dKH 11
    dGH 14
    tank water 13hrs AFTER co2 turns off 7.5 pH
    degassed tank water 8.2 pH in a separate cup
    co2 is on for 8hrs (1 pm to 9 pm, cerges reactor 4.5" x 20") pumping at 100ml/min. pH drops to 7-7.2 after 1hr, it's close to 6.6-6.8 pH by 9pm. Lights are on from 2pm to 10pm.
    i guess my main question is if i should be worried? the fish dont seem to care about the high amount of co2.
    now if i want to save on co2 can i just set the timer to shut off a few hours earlier? or would getting a ph meter be a better idea? how important is it to get a 1 point drop before the lights are on?
    #1 SingAlongWithTsing, Apr 14, 2017
  2. rajkm
    rajkm Article Editor
    Sep 16, 2015
    677
    218
    9:07 AM
    I would continue with static injection and use PH meter only to monitor the readings.
    I have set a air pump on timer which starts about 10.00 PM when all other ambient light in my room is off. I keep it on for 3 hours which is generally enough because that is a powerful airpump, your case might be different.
    With a wet/dry you O2 levels should already be up and should help degassing. Surface scum build up could be another issue, if so I would add a skimmer.
