Re: CO2 Misting
I have found a problem with my transparent spray bar. What looked like diatom algae grew inside, partially plugging the holes, but, worse, partly damming the CO2 bubble flow down the bar. The bubbles began to coalesce into large bubbles and burp out the holes occasionally. That caused my ppm of CO2 to drop and BBA began to grow - fast!
I removed the spray bar completely and now just use the outlet of the powerhead to spray the bubbles down the length of the tank. That seems to work pretty well too. Another problem is plugging of the inlet to the powerhead, gradually reducing the flow from it. One more routine maintenance job to do.
Yes, cap the opposite end of the spray bar, otherwise most of the flow and bubbles will come out that end.rrguymon said:Sounds interesting. Do you put a cap on the end of the spray bar on the oppissite side from the pump?
