Hypothesis:
CO2 mist pulls up the "good" periphyton that protects against algae spores(at least some/certain species) and things you'd rather not grow on the plants. Extra cellular polymers(ECPs) are excreted by bacteria on these periphyton films on leaves, these can slough off naturally, reduce turbidity and enhance water clarity. Reducing mist (but not 100% reduction) can enhance clarity and perhaps preserves some/most of the good periphyton that acts as a protectorant to "bad" algae colonization.
Unhealthy plant leaves, do not support a "good" periphyton community and too much CO2 mist might damage the periphyton a little bit. We still see good plant growth, but there's a ratty look to some plant leaves, detritus(likely the ECP's) hanging from them a little bit. This detritus is reduced and clarity is enhanced when there is less mist.
So a mix of the of a little bit of mist with the improved water clarity seems to be ideal based on observations blending needle wheel and reactors together to minimize the mist entering the tank, but not having the reactor fill up with gas later in the day.
The periphyton films may be what helps plants dominate in rich nutrients against algae, and to have healthy "good" periphyton.....you need healthy plants. This may suggets why healthy plants are able to protect against algae and define the system via the periphyton communities, rather than bottom up models like nutrients.
O2 and leaching from the plant leaves(say healthy active growing plant leaves vs non healthy) may play a large role in defining these periphyton communities.
More on periphyton:
http://edis.ifas.ufl.edu/ss522
http://cwam.ucdavis.edu/Volume_2/CWAM_II_4_Periphyton.pdf
http://algae.fiu.edu/
Testing methods:
http://water.epa.gov/scitech/monitoring/rsl/bioassessment/ch06main.cfm
More on periphyton:
Testing methods:
