I just recently bought a couple of Sweetwater Air-stones to try the CO2 mist method. I have a few questions for those of you already using this method.
I will need a solenoid plumbed into my regulator for this right? Unless I want to shut the co2 on and off every morning and night that is…no thanks.
Does anyone know of where I could get a cheaper solenoid valve? I saw some on an aquatic website for like 60 bucks. I’m hoping I can get them cheaper than that, considering I’ve seen them with a regulator for 70ish…
When I set this up what should I set the pressure on the regulator to? I think I had to up it to 40 psi to get good micro-bubbles when I tested the stones.
Doesn’t running it at this high of pressure use more gas?
Sorry if some of these questions seem a bit basic..>I just want to make sure I'm getting things right.
