The bicarb uptake is where the flow messes things up.
The H+'s come out the bottom of the leaf, coverts the HCO3 to CO2 via pH change, the leaf takes it up. This is called indirect bicarb use. Other plants/algae use direct bicarb use, they actively use HCO3, kick off the OH, and take in the CO2.
The OH rises pH often to about 10 or higher. Algae and some plants make specific deposits to make their CaCO3 precipitate formations.
At high current, this means it gets tosses away from the leaf and wasted.
No CO2.
If we add CO2, this is not an issue.
If we use CO2 mist, then neither is an issue, the mist disrupts this boundary layer quite well I'd imagine.
The common enzymes: Carbonic anhydrasae(CA) and PEP carboxlyase(PEP)(C4 plants etc). We have CA as well for our blood and balancing the ratio of CO2 to HCO3.
Carbonic anhydrase - Wikipedia, the free encyclopedia
Most aquatic plants and algae have carbon concentrating mechanisms as well, this means more cO2, less O2 around Rubsico, so it runs better. Also, with carbon fixation, you get a lot more/better results when N is not limited.
This is why EI dosing can drive much higher rates of CO2 fixation than say more limiting methods. Some claim this is the way/path to reduce the rates of growth and reduce the CO2 demand, hogwash, use less light and you get that and more wiggle room. Much easier, less work, less waste and less algae growth as well.
Here's another reference:
ChemPort Reference Linking Service
You should realize something though..............why do all this to get CO2, unless it is limiting growth in the first place?
It's neat etc, but does not apply to us unless we are limiting CO2.
Since we are not trying to do that, no one this is done
More in book form:
Plant Physiological Ecology - Google Book Search
