You have the reactor set up right I think the main problem with the am 1000 is the barb size, there's a lot of restriction there. The other difference is the am 1000 is 3" my media reactor that was converted is about 6" with 3/4 barbs.
ltb420 said:From what I can take in you may just need to adjust the level that the bleed line is set at. At this point I would reset the reactor with the bleed line closed and check where the gas bubble is at when the graph bottoms out. That should be close to the level you should set the bleed line at.
