Cheaping Out?
Actually, I think all of you are right.
For one, ‘cheaping out’ doesn’t convey quite what I meant and SuperCooley1 is certainly correct when he so eloquently and correctly points out the object of our CO2 use.
Though I will openly state I do come down on the side of the reactor; in the reactor versus diffuser debate at least as far as efficiency of CO2 usage. I have seen beautiful and magnificent planted aquaria keeping marvelously high and constant levels of CO2 in solute, using diffusers and I begrudge no one there use.
Philosophos’ point is well made; aesthetics and expectations certainly play an important role, ultimately perhaps the only real role.
Tom Barr is as usual correct and even gives us a method for testing in the meaningful way that would satisfy (and has satisfied me) SuperCooley1.
SuperCooley1’s well made point that ultimately what should concern us is the CO2 that we get past the Prandtl boundary layer along the plant leaf.
In effect the good Professor Prandtl, has defined a number of problems we face in getting our, plant friendly carbon disbursed. SuperCooley1 in truth makes an excellent point with respect to the movement through the water, the aforementioned Prandtl also has a number that adds to our problems in affecting that perfect circulation for CO2 as well as nutrient distribution we all seek.
One point on which the ever-erudite SuperCooley1 and I part company is over the issue of weather seeing the bubbles make any difference to the ‘out-gassing’. In a perfect system, indeed any CO2, or other gas entering solution would indeed ‘disappear.’ That gas in solute would be relatively difficult to remove from solution. Just as CO2, dissolves relatively easily into water (the thing that started the topic), it in fact leaves solute with some difficulty.
I will stipulate as obvious that while a bubble of CO2 (or any water-soluble gas) remains in contact with water some gas is dissolved and that the smaller the bubbles the greater the total surface area the better the gas will dissolve.
Hence, from my view a diffuser bubbling into a ‘dome’ or other container holding the gas in contact with the water longer would increase markedly the efficiency of the diffuser.
The subject that I was addressing was somewhat more a practical matter. I stand by my statement as a practical matter those bubbles are wasted CO2.
I fear, I allowed myself to be influenced by, and rather seeing this thread as a continuation of a couple of other of Scott’s threads. As well as other discussions of volume of CO2 used. I have done quite a bit of reading and found tremendous, I might even say irreconcilable differences in claims.
I will note that I was rebuked for suggesting that the expensive-Japanese-guy may have efficiently diffused CO2 into his tanks.
While an illness prevented me from completing the experiment, some years ago I did the experiment that the Tom Barr has suggested here, to my satisfaction, convinced me of the inherent efficiency of reactors over diffusion in supplying aquatic plants with plant friendly carbon.
I see nothing wrong with using diffusers or any other method so long as it pleases the user.
After saying all of this, I believe that we may well all have the wrong end of the proverbial stick. I think it may very well have been staring me in the face, at times like these, I wish I had a brain.
