Co2 Concentration Equation
Discussion in 'CO2 Enrichment' started by osmar, Jan 4, 2018.
  1. osmar
    osmar New Member
    Oct 2, 2017
    5:41 PM
    I read somewhere here that co2 can be estimated: co2 = 3x10 ^ x; x = displacement
    that's true? where this equation came from
  2. Phishless
    Phishless Lifetime Member
    Jul 13, 2017
    1,116
    969
    3:41 PM
    It solves for all positions in the CO2 charts that are out there.
    I don't know where or whom came up with this?
    [​IMG]
    Greggz likes this.
  3. Allwissend
    Allwissend Article Editor
    Jun 20, 2016
    498
    275
    9:41 PM
    At the basic level it comes from here :
    CO2 (aq) + H2O <--> H2CO3 (aq)
    H2CO3 (aq) <-->H+ (aq) + HCO3- (aq)
    HCO3- (aq) <-->H+ (aq) + CO3 2- (aq)
    that H+ influences the pH, per the definition of pH
    pH=-log10[H+]
    Then you have a lot of math and constants, add to that a lot of approximations for temperature, relative pressure etc.and you get your formula.
    I would start reading here :
    http://www.thekrib.com/Plants/CO2/
    And if you feel sciency , this explains a little bit better why the theory behind it works
    http://www-naweb.iaea.org/napc/ih/documents/global_cycle/vol%20I/cht_i_09.pdf
    also
    http://ion.chem.usu.edu/~sbialkow/Classes/3650/Carbonate/Carbonic%20Acid.html
    And after all that theoretical work you come back to the aquarium where so many things in the water affect the pH and KH is not only carbonates and you discover it does not apply 100% to real life. Can serve as a basic guideline but better to watch your fish and plants
    Greggz likes this.
Tags:
