Tom,
The last couple of days, you posted about injecting O2 and CO2 using a reducing T's (these are on PlantedTank.net). This thinking has me intriqued as I had thought about plumbing an O2 line into my CO2 reactor but was given feedback that would not be good.
I have several questions about them and thought this might be the best place to list them.
1. Are you suggesting that injection with the reducing is better than a reactor when a Cannister filter is used to drive the flow?
2. Will the CO2 mist or dissolve? Would this be decided based on the flow rate?
3. Will the O2 mist, buble or dissolve? Again would this be decided based on the flow rate?
4. Won't the excessive O2 bubbles cause the CO2 to de-gas faster at night, thus causing increased Ph swing which would result in more BBA?
Thanks,
John
Thanks,
John
