Co2 And Air Stone
Discussion in 'CO2 Enrichment' started by clambier, Apr 16, 2018.
  1. clambier
    clambier New Member
    Aug 15, 2017
    6
    10:21 PM
    IF i have started to run co2 rather then excel should i be taking out my air stone as i have heard it counter acts pressurized co2
  2. Christophe
    Christophe Subscriber
    Oct 3, 2013
    394
    253
    3:21 AM
    You might just have to run the CO2 slightly higher to get to a good pH drop. Maintaining good gas exchange is more important than minimizing CO2 use. Keeping good surface ripple is actually more effective for gas exchange than an airstone.
  3. Tim Harrison
    Tim Harrison Lifetime Member
    Jul 7, 2017
    242
    239
    3:21 AM
    It's not going to counteract the CO2 conc in your tank as such, it's possible to maintain optimum CO2 and high O2 at the same time; the two are not mutually exclusive.
    The stream of air bubbles hitting the surface may cause enough surface disturbance to degas your tank's CO2 at a faster rate than a gentle surface ripple, created by a lily pipe for instance.
    I'd aim for a gentle ripple like @Christophe mentioned above. But using an airstone at night is a good idea If you want to increase gas exchange when plants aren't producing O2.
Tags:
